8N Timing Gear cover
Posted by Del Huebner on June 29, 2020 at 17:41:46 [URL] [DELETE] :
Have a blem on the bottom of the hole where the govenor mounts. Just enough to let some oil drip out. The govenor face is completely flat . Can I put some epoxy sealant at the area it leaks along with the new gasket or should I cover the the whole mounting surface with the epoxy and the new gasket?
