Re: oil pressure
Posted by TheOldHokie on June 28, 2020 at 19:00:23 [URL] [DELETE] :
In Reply to: Re: oil pressure posted by gary on June 28, 2020 at 10:52:42:
OK - you did not replace the pump - you replaced the pump gears. Did you measure the face width of the new pump gears? Read this thread over on YT - similar problem solved by measuring the clearances to identify the culprit:
Bad Replacement Oil Pump Gears
TOH
