Re: Belt Adjusting Arm (Part # 8N-10145)
Posted by Tim Daley(MI) on June 28, 2020 at 05:23:17 [URL] [DELETE] :
In Reply to: Belt Adjusting Arm (Part # 8N-10145) posted by Jim on June 27, 2020 at 10:01:44:
HiYa Jim-
The 8N-10145 generator Tensioning Arm bolts to the governor and the generator support bracket. I have a dozen or so OEM arms if you need one. This is used on the early 8N's with front mount distributor only. Fan Belt tension is vital to charging the generator/electrical system/battery -without tension you are flogging a dead horse. The side mount dist introduction revamped the gen and moved it to the LH side of engine and it had its own tensioning bracket.
8N-10000-A GENERATOR w/ 8N-10145 TENSIONING ARM:
FORD 8N TRACTOR -48/50 GENERATOR BELT TENSION ARM 8N-10145:
*Used only on early 8N generator with the front mount distributor.
