Re: Jet size
Posted by JMOR on June 24, 2020 at 16:25:06 [URL] [DELETE] :
In Reply to: Jet size posted by Pete Landon on June 24, 2020 at 12:26:03:
Another thought. The ultimate mixture is set not by the main jet, but by the power adjust needle. Main jet & power adjust needle are in series , so the smaller opening sets the mixture. If you can back the power adj needle out far enough (3 + revolutions)to make it run rich (black smoke)then you can be sure that main jet is plenty large!
