Re: oil pressure
Posted by Bruce(VA) on June 17, 2020 at 11:34:04 [URL] [DELETE] :
In Reply to: Re: oil pressure posted by gary on June 17, 2020 at 09:10:08:
I'm getting confused here on the sequence of events.
Is this the order of what happened?
You rebuilt the engine, it only had oil pressure after you filled the lines w/ air, and it ruined the crank as a result.
Next, you replaced the crank, installed a new pump, did NOT align bore the engine?
Is that what happened?
Did you plasitgauge the rods/mains?
