Re: 1950 Ford 8n Funk 6 cyl
Posted by KCM on June 16, 2020 at 18:21:58 [URL] [DELETE] :
In Reply to: 1950 Ford 8n Funk 6 cyl posted by Steven Dyer on June 12, 2020 at 23:35:12:
Sounds like your #1 question was answered sufficiently. An easy way to tell if it is on compression stroke is to take out the spark plug and put your finger over the hole while you turn the engine. You will feel the pressure when it is coming up on compression. As for #2, yes and yes. Depending on how they were installed, a mechanical fuel pump could be used or they can simply be gravity fed without the pump.
