Re: 54 NAA
Posted by John in Mich on June 15, 2020 at 19:39:07 [URL] [DELETE] :
In Reply to: 54 NAA posted by LJ on June 14, 2020 at 22:19:02:
No, you di o need to completely drain the block. Just coolant level below the thermmostat. I can't tell you how much fluid that is but your system is close to 14 quarts. If you drained half you should be ok to pull the thermostat.
