Re: weak spark at plugs
Posted by Greg on June 14, 2020 at 12:13:50 [URL] [DELETE] :
In Reply to: Re: weak spark at plugs posted by TheOldHokie on June 13, 2020 at 15:26:06:
Update: Went out to tractor a little while ago. On a whim I pulled the condensor out and put in a condensor from an old Bolens 1054 tractor(tra 10d motor). It now starts pretty fast instead of turning over for a while with choke out.It actually idles pretty decent with minimal sputtering and don't smell the gas rich exhaust now. It will go on fast idle as well with a miss here and there. Full throttle and it misses with occasional backfire and will not get up to full speed. At fast idle it still lacks power. Am I right to assume my problem could be a bad condesor? If so what is the best one to buy. The one I took out was not that old but seems to have failed.
