Re: New gas leak
Posted by Tim Daley(MI) on June 10, 2020 at 05:17:17 [URL] [DELETE] :
In Reply to: Re: New gas leak posted by Frank (WNY) on June 09, 2020 at 16:12:52:
Have you tried contacting the place where you bought the fuel line and asked them? Reliable sources will look into it and/or replace the defective part. I've had defective parts made in Cheena replaced before by Steiner, Carpenter, & Barkley [sounds like a legal firm ; > )] and their suppliers fixed the defects. A very good possibility with the fuel line is the 1/4" tubing isn't flared enough to seat correctly. If you have a Flaring Tool Kit you could try to flare the end more or cut the end off and re-flare it altogether and see if that works.
