Re: Ford 8N Starting Problems. Please Help.
Posted by Jack - Iowa on June 09, 2020 at 14:21:18 [URL] [DELETE] :
In Reply to: Ford 8N Starting Problems. Please Help. posted by Tim on June 09, 2020 at 09:49:05:
Just watched your video.
That is WAY more choke than is normal on these engines. My thought leans towards a vacuum leak.
Spray some starting fluid, WD-40, Brake cleaner or such around the intake manifold including the gasket where the carb mounts.
If you have a helper it's best to do that while a starting attempt is being made. That way you can pretty well pinpoint the leak.
Good Luck,
Jack
