Re: New gas leak
Posted by Frank (WNY) on June 09, 2020 at 08:39:29 [URL] [DELETE] :
In Reply to: Re: New gas leak posted by Tim Daley(MI) on June 09, 2020 at 07:36:18:
Hi Tim, my original problem was a slow drip from the tank through the valve into the bowl with the valve turned off. I bought a new assembly from just8nís and installed it. That one wasnít any better and still leaked through the valve. I swapped the stem from the old assembly and that stopped the leak. I bought a new fuel line along with the valve installed it and didnít see any leaks. The tank had about 2 gallons in it and drove around with it. I filled the tank with another 4 gallons drove some more and when I went to shut off the valve, thatís when I saw the gas leaking from the flare fitting under the flare nut at the valve outlet.
