generator and ampmeter
Posted by Neal Fitze on June 05, 2020 at 13:58:26 [URL] [DELETE] :
1949 8N 233---; 6 volt; front distributor. I replaced all distributor parts and coil; regulator; resistor block; plugs; good wires; starter. Now she fires up great and runs smooth BUT, the amp meter shows over thirty amps! That is not good for the battery. I copied exactly the same hook up to the regulator, one connection at a time. What is going on??? Thank you. Neal
