Re: Choke
Posted by Walt/Tx on May 21, 2020 at 11:24:23 [URL] [DELETE] :
In Reply to: Choke posted by Ron on May 21, 2020 at 07:50:17:
When my jub was doing that it was the gaskets on the throttle shaft sucking/leaking air. These little gasket/seals do not come in all carb kits. I never thought they were that important but they are. Also if bowl gasket is leaking air you’ll get same effect.
