Re: Locked up motor after rebuild
Posted by steveVa on May 20, 2020 at 10:35:23 [URL] [DELETE] :
In Reply to: Locked up motor after rebuild posted by Scott on May 19, 2020 at 11:59:57:
I would oil everything real good with 5w20 rings and all, make sure you kept main caps in order with orientation etc. Try turning with a breaker bar like toh said. If it won't turn with a wrench, rock it in high gear and see if it budges.
