Re: Locked up motor after rebuild
Posted by bkrsdoz on May 19, 2020 at 16:38:49 [URL] [DELETE] :
In Reply to: Locked up motor after rebuild posted by Scott on May 19, 2020 at 11:59:57:
I assume you checked all mains and rod bearings with plastigage for clearance.
You also checked piston ring end gaps before assembly of the pistons/rods.
It shouldn't have been that tight on the stand.
