Re: 8n issues (6V, front mounted distributor)
Posted by Mike W on May 18, 2020 at 21:01:39 [URL] [DELETE] :
In Reply to: Re: 8n issues (6V, front mounted distributor) posted by Tony on May 18, 2020 at 08:17:23:
I would be interested to see how the governor reacts to the engine being placed under load. It should open the throttle smoothly and steadily to compensate for the need for additional power.
I worked on one where the throttle wouldn't stay where it was supposed to. The spring at the base of the throttle shaft needed to be repositioned on its mounting brackets. Doesn't seem like there's much difference one way or another, but it was the answer.
