Re: 9N Oil Canister
Posted by Tim Daley(MI) on May 16, 2020 at 09:15:22 [URL] [DELETE] :
In Reply to: Re: 9N Oil Canister posted by Bob on May 16, 2020 at 08:12:22:
Bob-
No, 1/32" is half of .062", or 1/16" ... plenty of passageway. Are you having problems? What does you gauge read at start up? At warm idle? OEM spec is 27 PSI at start up idle. If your gauge reads much lower when hot, engine likely tired and worn. The system has worked for over 700,000 models so I'd advise to leave it as is.
