Re: 9N Oil Canister
Posted by Tom on May 16, 2020 at 07:40:49 [URL] [DELETE] :
In Reply to: 9N Oil Canister posted by Bob Ward on May 16, 2020 at 06:28:47:
The oil filtration on flathead Ford V8 and N tractor engines is a bypass system. A small amount of oil is bypassed from the engine oil flow to go to the filter and drain back into the crankcase. This bypass flow must be small so that adequate flow is supplied to the engine.
