Re: 8N oil pump issue
Posted by TheOldHokie on May 15, 2020 at 19:10:42 [URL] [DELETE] :
In Reply to: Re: 8N oil pump issue posted by steveVa on May 15, 2020 at 07:30:41:
In attempt to understand this problem I went to the trouble of building a bench test rig for the oil pump. I could put what looked like a perfectly good rebuilt pump on the rig, prime it, and it would pump like crazy, Let it set for 30 minutes and it pumped fine. Let it set for 2-3 hours and it would not pump without priming. There is more to this problem than meets the eye and it is not the pickup system.
TOH
