Re: REAR WORK LIGHT
Posted by terry trasatti on May 09, 2020 at 18:29:08 [URL] [DELETE] :
In Reply to: Re: REAR WORK LIGHT posted by Tim Daley(MI) on May 07, 2020 at 11:52:03:
I gave up with the clips--used silicone sealant
my light does not have a hole in the attaching bolt, nor any other hole
I fished a wire thru a very small opening at the bottom near attaching lug, but I was concerned that insulation would wear thru and short out, so I drilled it out to accept a grommet
what is wiring routing from light to ignition switch? I see routing clip in wheel well and on left side of trans, but then what??
