lift arm removal 8n
Posted by Dan on May 09, 2020 at 17:57:36 [URL] [DELETE] :
Is there a special ford puller to get the hydraulic lift arm off the spline shaft on 8n ? Nothing comes off easy on this girl .... The rocker shaft also needs to come off some one sawed both sides off and it is rust welded in place .Huge fat 3 pound punch and heavy small sledge and penetrating oil do nothing . I fear that part will need more sawing and will have to drill it out ....
If once the lift arms are off any chance of getting bad bushing out with out removing cover ... Probably not .......
