Re: Dirt Scoop - Which way should it face? Stabalizers?
Posted by Jimmyjack on May 07, 2020 at 20:52:32 [URL] [DELETE] :
In Reply to: Re: Dirt Scoop - Which way should it face? Stabalizers? posted by Tim on May 07, 2020 at 16:55:11:
I like it best facing away from the tractor for most uses. Its easiest to fill backing into a pile, and dumps and levels very good going backward on fixing roads, potholes etc. I also use it for hauling wood, and like a work box. If you have it at the right level when you trip it going backwards it works like a grader blade. Try it each way, your chores and soil will determine what is best for you.
