Re: Ford Jubilee Hydraulic Options
Posted by TheOldHokie on May 07, 2020 at 16:36:54 [URL] [DELETE] :
In Reply to: Ford Jubilee Hydraulic Options posted by Austin on May 07, 2020 at 11:10:57:
Glad you asked. The NAA was a crossover model that got limited support. The hydraulic options were primitive and if you do find them today expect to pay dearly. Ford had a much better idea with the Hundred series and I have attempted to duplicate it for the NAA. This hydraulic plate is the NAA version of the HV5902 plate sold for the Hundred and Thousand series tractors. It gives you a pressure out and power beyond return to the hydraulic cover. A low pressure tank return is provided via the sump filler. This is how modern tractors handle the addition of remote valves and you can use it to mount any modern 1, 2, 3, .... spool valve on your NAA and use it independently of the 3pt. Beats the heck out of the Ford Selectrol switching setup. If interested give me a yell.
TOH
