Re: Hydraulic lift issues 51/52? 8N
Posted by JMOR on May 07, 2020 at 16:31:30 [URL] [DELETE] :
In Reply to: Hydraulic lift issues 51/52? 8N posted by CaptainB on May 07, 2020 at 10:57:44:
The control shaft has eccentric on end that passes thru control arm and as shaft is turned by touch control lever, the eccentric causes the control arm to move fore/aft, thus changing position of control valves. Full rotation "might" move control arm more than normal and if far enough, "might" bend control arm. Never tried it, thus the "might". Remove right side round cover to see control arm and see if still straight or bent.
