PPS>
Posted by TheOldHokie on April 28, 2020 at 19:39:32 [URL] [DELETE] :
In Reply to: Re: Back to Old Hokie posted by TheOldHokie on April 28, 2020 at 19:31:25:
When you start adding the new pump and valve keep in mind the ports are SAE o-ring and not pipe thread. If you try to screw pipe fittings into them you will be making an expensive mistake. Order the correct port adapters along with the valve and pump.
TOH
