Re: Double shifting unsynchronized manual transmission
Posted by Bruce (VA) on April 24, 2020 at 09:53:49 [URL] [DELETE] :
In Reply to: Double shifting unsynchronized manual transmission posted by Brad on April 24, 2020 at 09:14:57:
It's called double clutching.
Get up to speed, clutch in, shifter in neutral, clutch out, shifter in next higher gear.
That's how I shift my Model A Fords because at some point, you want to go faster than 10 mph in a car. And the transmission is geared accordingly.
But that's not the case w/ a tractor. You can start in any gear easily.
Yes, you can double clutch an N and shift while moving......and what does that get you? Because as you are learning how to perform an unnecessary task, you will be grinding the gears.
Just like starting an N w/ a hand crank. Want to see how easy it is to break your wrist? ;)
