Re: Ford Jubilee Motor Rebuild Update
Posted by Scott on April 22, 2020 at 10:11:51 [URL] [DELETE] :
In Reply to: Ford Jubilee Motor Rebuild Update posted by JR in AR on April 21, 2020 at 18:15:04:
I just picked up a 8n motor I had at the machine shop. They removed and installed the sleeves, trued up the deck of the block and the head, valve job and install valve train and install a few helicoils in some stripped oil pan bolt holes. Plus they cleaned the rods and installed the pistons and bushings onto them. And some miscellaneous work as well, all for a shade over $1100.
