Re: Pump base bolt torque specs
Posted by Travis Webb (UT) on April 21, 2020 at 19:57:47 [URL] [DELETE] :
In Reply to: Re: Pump base bolt torque specs posted by Tim Daley(MI) on April 21, 2020 at 05:56:18:
Lining the pumps up side by side, the bolt holes seem to line up; however when it was in the tractor, I needed to move the pump about 1/4" to the right, to line up the holes on the center housing, and it wouldn't move. I shouldn't need to take the top lid off should I? Also, one thing I forgot to mention...the PTO shaft does not go in to the new pump as easy as it should. It would slide in and out of the old pump with no problem at all; I had to hammer it in to the new one pretty aggressively. (I didn't damage anything with the splines). Possibly a defective unit?
