Paint? insulation spray> reroute? heat from manifold on 600
Posted by Charles on April 20, 2020 at 17:40:00 [URL] [DELETE] :
I'm not sure how to treat on painting around manifold and muffler on Ford 600. concern fire from regular enamel paint on heat shield and fan air deflector. I'm also questioning on gas line boiling. I have decided to not paint heat shield (looks to be stainless steel). I would like to not reroute gas line around and not thru, manifold area. Is there a high heat resistant-spray insulation
Is it possible to move the muffler out from under hood , but still use current tailpipe under tractor?
I am using in this order rest of tractor. sand, wire brush, rust restorer, primer- Old "genuine New Holland red enamel (I know laquar would have been a bwtter choice)
Comment desired
Charles on my Quartine therapy. Need warm weather to move outside to spray paint using new gravity airless sprayer. brushed on primer/
Today spray can paint front pulley area using only TS rattle can spray can (worked good in tight area and right color)
