Re: High-Low Aux Trans
Posted by John in Mich on April 17, 2020 at 17:29:23 [URL] [DELETE] :
In Reply to: Re: High-Low Aux Trans posted by Jeff on April 17, 2020 at 16:53:32:
What Carl said. You want the Combination trans that you described below. Step down first and step down 2nd are both lower speed than first gear. Also understand, changing the input to the standard transmission also changes the RPM of the PTO if you are going to use the PTO.
