Re: craiglist 9N or 8n
Posted by Scott on April 14, 2020 at 21:07:43 [URL] [DELETE] :
In Reply to: craiglist 9N or 8n posted by Joshua on April 14, 2020 at 15:49:50:
That's a 8n block. The heads on 9ns are held on with studs and nuts, not bolts. Of course over the years they could have been changed out. I would be skeptical of the rebuild though. I don't think RTV should be used on a head gasket. I think if you look around a bit, there are better tractors out there. Or go ahead with it with the understanding that it might be a little more work that originally thought. Good luck
