craiglist 9N or 8n
Posted by Joshua on April 14, 2020 at 15:49:50 [URL] [DELETE] :
need some advice on a 9n I found on craiglist.
$900
The good: rebuilt motor (proof with pictures), New fuel tank, radiator, carburetor, gauges and front tires.
The indifferent
8N serial number on a 9N transmission and rear end. Front mounted distributor
The bad
No oil filter housing, no air breather, push button start is inop he has been using a battery cable to go from the battery to the starter to hot wire it.
Turns over good compression but wont start.
I talked him down to $750
Is it worth it? Where do I start?
