Re: Pie wheel weights
Posted by Kirk-NJ on April 08, 2020 at 05:56:03 [URL] [DELETE] :
In Reply to: Pie wheel weights posted by Brad on April 06, 2020 at 14:54:17:
Here's a set off homemade steel plates on my Ih 240. They are 225 each. I have also seen some made out of manhole covers. Scrap yard might have something laying around you can use.
For concrete weight you can lay your tire down and weld a pipe on the disc bigger then the center drill a couple few bolts in then cut a big piece of sona tube and pour. Worked good on my 641
