Re: 2N No Power
Posted by Jason on April 06, 2020 at 16:38:35 [URL] [DELETE] :
In Reply to: Re: 2N No Power posted by Bruce(OR) on April 03, 2020 at 22:38:55:
Ok. So I did little “check the easy stuff”. Found that #3 and #4 spark plugs were reversed. Down side is that now it won’t run. Wants to fire but not run. Wants to fire at 3/4 choke closed. Sounds like not enough fuel? How should I adjust carb to start out with?
A few other tidbits. 6v negative ground. It has an alternator, but it’s the two wire AC Delhi type and not hooked up. Neutral safety switch is operational.
