Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 05, 2020 at 20:04:15 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 19:21:32:
Oil is flammable. You need to get the crack clean and grease/oil free. I cant see any need to remove the pump ss long as you can get it cleaned up.
