Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 05, 2020 at 15:28:31 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 15:14:44:
JB Weld is not going to hold 1500 PSI. If it were mine I'd be looking for a cheap pump but I would not rule out trying a repair with aluminum brazing rod. Basically a question of how deep your pockets are and how much time and effort you want to expend.
TOH
