Re: Leaking hydraulic pump assembly drain plug bolt
Posted by Travis Webb (UT) on April 05, 2020 at 13:57:47 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 13:00:06:
Here's a closer picture of the crack. Also, I have a video I can email as well. I did some testing, and the leak really starts when I lift the 3-point arms up; when I put them down, the leak stops, or slows drastically. It also seems to be leaking mainly from the back, where the silver meets the red paint; possibly a gasket?
