Re: Leaking hydraulic pump assembly drain plug bolt
Posted by Travis Webb (UT) on April 05, 2020 at 13:00:06 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by TheOldHokie on April 05, 2020 at 12:29:30:
Thanks...will get a washer tomorrow and check it.
I don't think the picture of the crack came over, so here it is. The fluid is streaming out, as if the bolt isn't there.
