Re: Leaking hydraulic pump assembly drain plug bolt
Posted by Tom on April 05, 2020 at 11:22:07 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 11:05:14:
If that is a crack and it does not go into the threaded area, a good welder might be able to TIG weld it.
