Re: Leaking hydraulic pump assembly drain plug bolt
Posted by JMOR on April 04, 2020 at 23:37:14 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Charles on April 04, 2020 at 20:03:25:
" When Hydraulic cyclinder goes down, the oil level increases in the case, causing the leak out the side bolt.
HTH"
Are you joshing us? One cup of fluid is going to change the level in 5 gallons by any significance??!!!!??
