Re: Paint colors on a Ford 600
Posted by Charles on April 04, 2020 at 18:51:16 [URL] [DELETE] :
In Reply to: Re: Paint colors on a Ford 600 posted by Tim Daley(MI) on April 04, 2020 at 18:07:13:
Thank you. Thank you.
You answer was right on plans and need. I have basically bought what you recommend, except the local CWH had old gallon of New Holland Ford Red and gray from 2N project, I bought primer from Ace Hwd. I bought some TSC spray cans of red. I disassemble , scape, sand, apply rust restore, brush primer and red (around under battery)all inside overhead propane heater (door open). On Fergy 1939 family jack.
Have bought airless sprayer and plan on moving it outside now as weather permits and spray. Small parts on clothline.
Plan on a complete rewire using operators manual as guide, except small alternator with machined V- pully Cell phone picture of wire hookup).
Fitted DC case wheel weights to rims (same angle) Lights are 12 volt from scrapped JD-45 combine.
Oil line is in back of HYD pump and inaccessible. Tractor all ready has a splice in line. new water temp unscrews.
Should heat shield between muffler and gas tank special paint (heat resistant?
