Re: Rotary mower and shaft length
Posted by Jock(OR) on April 01, 2020 at 23:33:37 [URL] [DELETE] :
In Reply to: Rotary mower and shaft length posted by Pete on April 01, 2020 at 21:20:54:
Shaft length needs to consider the over-running clutch you should be using on the PTO output. I think most are about the same length, but you should measure yours to confirm.
Different mowers could use different shaft lengths, depending on the cutting width of the mower and the design of the angle drive unit.
