Re: Ford 8N, won't start
Posted by Tony T. on March 23, 2020 at 20:40:02 [URL] [DELETE] :
In Reply to: Re: Ford 8N, won't start posted by Bruce (VA) on March 14, 2020 at 06:24:44:
Bruce,
We replaced the non-functioning starter with a new one. We followed the suggested starting sequence 3 times, with 2 minutes in between tries, she would not start. Also, gas began dripping from the carb again, despite following the recommended sequence. I put on an older spark plug with a 1/4" gap, we could not see a spark (the spark was seen at .020 and .030). So, it appears as if the spark is very weak. Next, I'll try the fuel flow test.
