Re: 49' 6 volt positive ground cable HOT!
Posted by Jack - Iowa on March 22, 2020 at 07:26:16 [URL] [DELETE] :
In Reply to: 49' 6 volt positive ground cable HOT! posted by Harry on March 21, 2020 at 11:43:45:
I should add:
If, when you pull the wires off of the first large post on the solenoid, your short does not go away, the heavy cable to that point is shorted to ground someplace.
