Re: Engine oil level
Posted by Tim Daley(MI) on March 19, 2020 at 18:05:06 [URL] [DELETE] :
In Reply to: Re: Engine oil level posted by John in MIch on March 19, 2020 at 11:25:53:
Well, it's a FORD so will leak some oil if hasn't already so watch for puddles and eventually the dipstick will show to line.... ; > ) [GRIN] When I do an oil change on my N's I never add the full 5 quarts. I add 3 via filler breather spout then start up engine and check for leaks. If no leaks I add another quart and will run it for a few days like that then check again and add as needed. At my oil changes I also service the air cleaner and the oil bath on that and refill with fresh clean oil. At every start up I go thru a checklist of inspections before starting up and oil levels are a few.
