Re: Kingpin no crank hole
Posted by TheOldHokie on March 16, 2020 at 09:15:37 [URL] [DELETE] :
In Reply to: Re: Kingpin no crank hole posted by Brad on March 15, 2020 at 20:22:28:
Good luck making a Wagner quick detach. The rear attachment and cylinder geometry is nothing like a modern loader with the bucket and cylinders pinned to a sub-frame. You are going to need something akin to a gantry crane to support the CG which is way rearward.
BTW, I have the front hanger weldments that includes the pin with through hole for the drive shaft.
TOH
