Re: Ford 8N, won't start
Posted by Jack - Iowa on March 14, 2020 at 07:36:38 [URL] [DELETE] :
In Reply to: Ford 8N, won't start posted by Tony T. on March 13, 2020 at 20:29:01:
In addition to what Bruce said, even though you know the plugs are dry, I would still burn them out with a propane torch. On my 2N I pull the choke out and release it. Normally that is all it takes.
Pulling it which removes the starter load from the battery might get it running also. Use 3rd gear.
