Re: generator belt adjuster
Posted by Tim Daley(MI) on March 12, 2020 at 14:26:39 [URL] [DELETE] :
In Reply to: generator belt adjuster posted by Rich on March 12, 2020 at 09:07:21:
HiYa Rich-
The OEM belt tensioner is NLA meaning no longer made or serviced -nobody repops them today. BTW YT does not make any parts, only supplies from vendors. The 9N/2N Belt Tensioner was first offered on the 2N-10000 generator as an attached part included with the unit. At the same time FORD offered an optional belt tensioner for the 9N-10000-C generator but used a steel belt that the barrel attached to. NOTE pictures show both. The optional device was a dealer supplied accessory. The generators were virtually the same unit, the same barrel diameter, a 1-Wire/3-Brush, 11 AMP, A-Circuit unit except the earlier 9N-C generator did not have the attached stationery bracket using two bolts. The steel band included the required bracket needed. I have a restored/rebuilt to OEM specs 2N-10000 complete with the belt tensioner for sale and also a tensioner kit for the 9N-10000-C unit. NOTE: The belt tensioner on the first two 9N generators, the '9N-A' and the '9N-B' units will not work. Email is open. My email IS open this time.... ; > )
OEM FORD 9N-10000-C GENERATOR WITH BELT TENSIONER OPTION NOTE STEEL BAND:
OEM FORD 2N-10000 GENERATOR WITH BELT TENSIONER ATTACHED:
