8N bogs down when turning on PTO and pulling shredder
Posted by Steve on March 03, 2020 at 13:41:56 [URL] [DELETE] :
In Reply to: Re: 8N bogs down when turning on PTO and pulling shredder posted by Tim Daley(MI) on March 03, 2020 at 03:51:51:
Tim, Yes, it is an aftermarket carb. Did not perform a fuel flow test, Ill look up how to do that. Also, I did not test the carb, just installed it.
Not sure if the original carb is original, how do you find that out?
What do you charge to rebuild?
Yes, its the original 6v electrical system with the generator, etc.
It first up on the first try, never really been a problem. Its just when I put a load on it that things go south fast.
