Re: 8N Flooding
Posted by Tim Daley(MI) on February 10, 2020 at 05:56:11 [URL] [DELETE] :
In Reply to: 8N Flooding posted by Cal Sexsmith on February 09, 2020 at 17:44:50:
Did the flooding just begin or have you done something to the carb you haven't mentioned? Are you turning the fuel flow valve OFF when tractor is shut down? When was the last time you serviced the carb? As you surmised, a stuck float or needle float valve is the usual culprit but there's only one way to find out. I'm not one of those that SMACKS things with a hammer, wrench pliers, or screwdriver as a 'fix'. Do the job right in the first time. If you are interested, I rebuild OEM Marvel-Schebler TSX carbs and ready can do yours if you are interested - email is open.
OEM MARVEL-SCHEBLER TSX-241/FORD 8N-9510 CARB PROFESIONALY REBUILT by TIM DALEY:
